2003-05-15 4:26 AM
2003-05-15 2:21 AM
I want to use STDV7 by selecting Hiware on Project Settings/Software toolchain. Which are the correct string that I must use on command lines? (Build, Rebuild etc.) Thank you in advance, William [ This message was edited by: friul on 15-05-2003 15:16 ]2003-05-15 4:26 AM
In the stvd7 directories are examples for asm,cosmic amd metrowerks.
It is usually located under C:\Program Files\STM\st7toolchain\stvd7\sim\sample\c\Metrowerks depending on your install. Regards SJOWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
