2006-03-22 6:57 PM
2006-03-22 5:40 PM
Micro used - ST7FL35
Compiler used - Cosmic Memory Model used - Medium Memory Model The physical stack grows from 0x1FF to 0x180, is it possible to reduce it to say 50 bytes? if so, the expectation is that stack should grow from 0x1FF to 0x1cd. On reaching 0x1CD it should reset back to 0x1ff and start again. -Suganya :)2006-03-22 6:57 PM
There is no way to change the hardware range of the stack area.
If you want to re-use the stack ram, it is up to you to handle the stack overflows.... Bye EtaPhiWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
