2005-01-18 11:39 PM
ST92F150 problem,can you help me ?!
2011-05-17 2:36 AM
I used a test program testing my chip .
it's work well on the ST9 HDS2V2 EMULATOR, but it doesn't work in chip. (power 5V,CRYSTAL SCILLATOR 0.6V,4M). it's I/O PIN output only 0.3V or so!!!? can you tell me how to do with the problem ?2011-05-17 2:36 AM
Is your Hardware throwing the Correct Reset to the micro?
Check it on Probe Is the Watchdog hardware or software enabled? Check Pin No 97. what is your application?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
