ST10Flash.cfg
ur2l846
Associate II
Posted on December 18, 2006 at 16:28
ST10Flash.cfg
4 REPLIES 4
ur2l846
Associate II
Posted on December 18, 2006 at 05:08
when I'm loading the ST10flasher.dll into my program its trying to parse a file ST10Flash.cfg. What's the purpose of this file (is it necessary for a correct functioning)?
Could you give me an example of how it has to look for the ST10F276?
najoua
Associate II
Posted on December 18, 2006 at 05:27
The ST10Flash.cfg file gives a description of the Internal Flash in all ST10 derivatives( Start address, End address, Blocks, sizes...).
This file is used with the last ST10Flasher Version: V4.2B.
You can find find it in PATCH_018UM.zip (in the ST10Flasher V4.2B package) which should be unpacked into the ST10Flasher installation directory.
You can find the ST10Flasher last version on the following link:
http://www.stmcu.com/modules.php?name=mcu&file=familiesdocs&FAM=17
Regards,
Najoua.
ur2l846
Associate II
Thank you, it works fine!
jayesh
Associate
Posted on March 31, 2010 at 22:35
We have used CFG file but still getting a run-time error
Please guide us
We are using VS6
Thnx
