2004-10-14 7:43 PM
2004-10-14 8:49 AM
2004-10-14 7:43 PM
I had nearly the same problem. The data that you had read may be read from another memory and not from the flash. Check That : - ROMEN bit in SYSCON register is set . - Verify that XFLASHEN bit in XPERCON register is set in order to be able to access the Flash Control Register I hope this will help you. [ This message was edited by: Najoua on 15-10-2004 09:31 ][ This message was edited by: Najoua on 22-01-2007 11:58 ]We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
