2003-08-07 6:23 AM
2003-06-10 11:47 PM
I'm trying to reprogramm a ST10F269-T6 device which is already mounted on a circuit. The St10 MCU is monitored by a L4969 device(system voltage regulator with a CAN Transceiver). I'm failing to get the MCU in Bootstrape mode. The problem is probably the watchdog on the L4969 device. How best can I deactivate this watchdog.
thank you!2003-08-07 6:23 AM
I really don't know the L4969, but try this:
The RESET state of the ST10 IO pins is HiZ. So trigger your watchdog input with an external oscillator and enter an undisturbed boot. hope it helps...We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
