2004-05-25 2:07 AM
2004-05-03 2:41 AM
Hi all!
I have a ST72C215G2B6-based device with ISP connector on it. I've found that Visual Programmer can do it's job through LPT port. So, the question is: how to build the simplest programmer? Sorry for ''stupid'' question, but this is my first ST MCU... I have some experience in MCS-51, AVR, PICs - but not in ST2004-05-10 5:36 AM
Check out flashbash: www.spen-soft.co.uk
2004-05-10 10:16 PM
Flash Bash has its own PC software and does not needs to be connected to a PC to operate.
If you want to use the ST Visual Programmer PC software you can build your own low cost LPT programmer using the STICK schematics/Bill of materials/gerber files that are available on this web site. Regards [ This message was edited by: Alaini on 11-05-2004 10:47 ]2004-05-25 1:21 AM
Just to point out: Flashbash operates in PC mode and stand-alone mode.
Cheers, Marty.2004-05-25 2:07 AM
please take a look athttp://www.softecmicro.com/products.html?type=detail&title=inDART-ST72C/SK
If you want to use a reliable solution you can choose inDART from SofTec Microsystems.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
