2007-09-27 7:25 AM
Problem going from ST7LITE05 to ST7LITE15B
2007-09-26 5:19 AM
I usually use the ST7LITE05 and develop my program in assembly with SOFTEC indart STX and STVD7. I'm trying to translate a old program from ST7LITE05 to ST7LITE15B and I have some problems to build my project. I get a build error and the map file seems to stay empty! I have attached the ST7LITE15B include files and everything looks good? Any idea on what happens and on how to solve it? Thank you for your help.2007-09-27 7:25 AM
Thank you SCo,
You can find added the error file I get. When I say ''attached files'' I mean that I have put the .include and .asm file for the ST7LITE15B in my project folder! The build process seems to be OK. The problem is that the .lst and .map file are not generated? (the .map file stay empty). Do you have a project working with a ST7LITE1xx controler running? In that case, could you send me the folder of this project (erase all you dont want to transmit in your .asm file). So I could start from this folder and no more from a ST7LITE05 project! Thank you for your help Regards Whitebull ________________ Attachments : cbe.err : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Cn&d=%2Fa%2F0X0000000bVJ%2FcpUNXwy3ndDwf20BRmC5rMnx5VaFmftx3pgCZKa6XO4&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
