2006-07-05 9:51 PM
2006-07-04 9:13 PM
Hi all,
I encoutered problem building kernel of uclinux. After having set arm str7 toolchain, and done the ''make menuconfig'' as described in the ST application note, I have a generated error during the ''make lib_only'' : ucfront-gcc : command unknowncc1.o Erreur 127[alkl]erreur 2I searched on the web , unsuccesfull !! Thanx for your helps, Rgds, ps: i turn on red hat (kernel 2.6.9-5) [ This message was edited by: jorge50 on 05-07-2006 09:51 ]2006-07-05 9:51 PM
I found a solution :
do a ''make ucfront'' before the ''make lib_only''. it seems to fix it! RgdsWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
