2006-01-05 11:04 PM
P0.15 can not be seted to High levlel
2006-01-05 4:02 PM
I use keil for arm
GPIO_Config(GPIO0, 1<GPIO0->PD |= 1<GPIO0->PD &= ~(1<in keil IDE, i can get High/low level. (I/O Port 0 Dialog box) But i can not get High level at P0.15 Pin, it is low level always. How can i do ?2006-01-05 6:56 PM
Hi shangdawei,
As the STR71x datasheet P0.15 is only an input pin. With best regards, Hichem ;)2006-01-05 11:04 PM
Thx, i found it here :
________________ Attachments : str7.p0.15.JPG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtNz&d=%2Fa%2F0X0000000aPF%2FI7WzAR6Ij0W5I_Y9Vj4kFS01Y8pPs.Y49ca1_KXZ4mQ&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
