2007-03-29 3:51 AM
2007-03-28 9:43 AM
Hi guys,
I have been programming and playing with a STR7 using the Oimex STR-P711 board, a JTAG wigler and a IAR EWARM Kickstart Version. I have reached the 32K code limit. I would like to know if there is some IDE or a complete set of tools in order to develop a bigger program on a STR711FR2T6. If some one could help me with the diferent tools, Pro, Cons, and even price range that are avaliable on the market... I would appreciated a lot. I have read about the Keil, IAR, Raisonance, Rowley, RealView. I have been investigating about an open source option. Actually I am triying to use the Eclipse + CDT + Cywin + GNUARM + OCDremote that it is supposed to be an alternative for program the LPC2xxx but I dont kwon what to do with the STR711 ... may be that option is worng. Could you help me with this??? Thank you guys2007-03-28 10:56 PM
Hi Guiy,
This is an interesting link that shows information about ST's partner and their debugger and compiler.http://www.stmcu.com/modules.php?name=mcu&file=devtools
Find also attached, some information about ST's third parties. it should give you a clear idea. :-] Now,if you're interested in one of this products ,ST give you the opportunity to buy on line from its web site, find bellow the link. ;)http://www.stmcu.com/modules.php?name=mcu&file=debug_tools&fam=86
I didn't try it but normally it should work :-W . find attached useful doc. Best regards, MBS [ This message was edited by: MBS on 29-03-2007 11:40 ] ________________ Attachments : ARM_Cross_Development_with_Eclipse.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtNp&d=%2Fa%2F0X0000000aPC%2FE97pFm2sH5f4wr.47KpUvfa.rIhX7GChceTb6WPGv9U&asPdf=falsebrstrtools1006.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtNu&d=%2Fa%2F0X0000000aPE%2FHHv5nzGnWm2ifwLiaRGjhv_dvik_aq1wXmNjCACU94Y&asPdf=false2007-03-29 3:51 AM
Thank You MBS.
