2005-08-22 2:02 AM
2011-05-17 3:08 AM
we used to use the PSD813 as program space and and EPROM in a socket as removable update-device. Everything worked perfect. - It´s an 8051-arcitecture. Now we use additionally for the first time the SRAM mapped in data space. During the update sequence we read from the EPROM, but now I will have to block or mask out the SRAM space. Is it possible to do that by changing the PSD-registers? Or what to do else?? please help! Linus2011-05-17 3:08 AM
Take a look at the definition of the ''VM'' register in the PSD data sheet. It controls what pins generate chip-selects for what pieces of internal PSD memory. You can use that to stop RD from accessing the SRAM.
