2011-09-08 2:07 AM
I am using STM8S208MB MCU for my application and need to design a Low Pass Filter for 500 Hz on the Analog Inputs. Has anybody designed and implemented this kind of LPF using the MCU. I need the filter of first or second order. Is it possible to implement it in the MCU??Are any documents available on ST site or Internet??Awaiting for positive repliesThanks & Regards,Pranav #low-pass-filter #fir #iir #lpf #filter. #low-pass-filter2011-09-08 4:26 AM
Do you mean:
In the 1st case, see any standard text on digital filtering and digital signal processing (DSP);
In the 2nd case, see any standard text on analogue filter design.2011-09-09 2:15 AM
We know the fundamentals of digital filtering. We are looking for a code for STM8 which can be used immediately.
Best,Rakesh2011-09-09 2:46 AM
You asked if it was possible - you didn't say you wanted a ready-to-use solution.
Have you looked at the resources that ST provide? Have you Googled?2011-10-20 2:32 PM
I think that you could see this:
