2005-11-14 2:17 AM
2005-11-07 5:33 AM
Hello
during my searching for documents I found, in my E:\Metrowerks\STM V2.0\lib\st7c_my_new\3rdparty\st7_lib2 a document called user manual.pdf. In page 9 - main directory structure - I found that there is ST7lib_config.h file that contains some #defines to compile library called lib2, that deal with: ADC, EEPROM, I2C, I2CSlave, IO, ITC, LART, LT, MCC, PWMART,SCI, SPI, TBU, TIMER, TIMER8, WDG, CAN. I understand it is for all st7 family, with small changes between the different flavors. Where can I get this library ASAP ???? Thanks a lot Oren2005-11-08 10:32 AM
Hy,
try to download the ST7 library from STM directly. These library are MW and Cosmic compliant and include many peripheral. By2005-11-08 9:23 PM
Hi
I alreay tried to look there :-[ I can't find it. do you have the link ? (Am I the only one who thinks that st site is very hard to navigate, and that the search results are never what you need) Oren2005-11-09 6:19 AM
Hy
try to download at this link. http://mcu.st.com/mcu/modules.php?name=mcu&file=familiesdocs&FAM=15#Software%20-%20Microcontrollers Search st library 2.1 ( about 5MB). After download. install it; then You ca be see the User Manual to undestand how the library are composed. Attention: the code is for an quickly start up but are'nt for all purpose. In sereral case I have modified it because are GENERAL PURPOSE. By2005-11-14 2:17 AM
:D
I found it. I will install it later. Thanks a lot!!!! OrenWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
