Is it possible to change certain pin's "pull-up under reset"?
TSu.1
Associate III
in STM8L151G3 the PA0, PB0 and PB4 is configured with pull-up under reset. I wonder if we can change it back to floating under reset?
1 REPLY 1
Peter BENSCH
What do you mean by "change it back"?
The behaviour of the pins under reset is fixed and documented in the data sheet, e.g. as foot note under table 27:
All pins except PA0, PB0 and PB4 are floating under reset. PA0, PB0 and PB4 are configured with pull-up under reset.
Does it answer your question?
/Peter
