2006-11-13 7:19 PM
2006-11-06 6:07 PM
If I run our ST711 application under IAR's C-Spy debugger (using a J-Link) none of the interrrupts get triggered. This makes debugging anything pretty much impossible. I've gone through the settings about 100 times already, but I can't find anything. The docs are not much help either. Can anyone help me out?
Just FYI, same project under RIDE works properly.2006-11-06 7:09 PM
Here's some more info. If I flash the device, then switch the debugger option to ''Attach'', then start debugging, the interrupts work properly. What am I missing ???
