2008-02-04 9:57 AM
2008-02-03 8:32 PM
We have to update to IAR 5.1 Unfortunately, they have changed many things ( I think to the worse). Has anyone hints how to compile the STR71-API, especially the assembler sources? Thanks, Steffen2008-02-04 9:57 AM
Hi Steffen,
I haven't migrated yet, but I came across Technical Note 40394 on the IAR support site. http://supp.iar.com/Support/?note=40394 Maybe you should have a look, as it explains the major changes, including on the assembler and linker. I think some assembly files need to be replaced with newer versions. Also, if you are on the web site, there is a 28 page migration guide (pdf file) that could help you a lot: ftp://ftp.iar.se/WWWfiles/arm/Guides/omarm_2.pdf Hope this helps a little. Regards, Tech / JpWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
