2004-03-09 11:40 PM
2004-03-09 6:59 PM
sir,
actually i want to erase /program 2 or 3 bytes at different locations in my s/w so i want to use iap for that. can you pls guide me the way to perform this and if you could pls send me the related documents. i am using '' st7flite02'' mc which does not have eeprom. pls support. i also want to retrieve the data written on locations. thanks best of regards shweta shweta_arora@elymer.com2004-03-09 7:41 PM
shweta,
there are several application notes about that: Hope this helps[ This message was edited by: friul on 10-03-2004 09:13 ]2004-03-09 11:40 PM
For detailed info, you can also refer ''ST7 Flash programming manual'' which is downloadable from the same site.
[ This message was edited by: Jatin on 10-03-2004 13:13 ]We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
