2004-05-14 4:04 PM
2011-05-17 3:00 AM
I got a problem in my IAP project. The boot firmware download my application F/W successfully. And the application F/W has started running in main flash. But the UART ISR in application never get executed. The same code works OK when being programmed into secondry falsh thru JTAG. I am thinking that UART interrupt is not redirected properly after memory swapped . Does any body know about that?
2011-05-17 3:00 AM
The issue is under review and update will be posted .
[ This message was edited by: uPSD on 15-05-2004 04:35 ]We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
