2019-06-04 1:02 AM
Hi I need the technical specifications from a MOSFET , A748, BUZ11
Thanks
2019-06-04 1:25 AM
2019-06-04 1:58 AM
Transistors/diodes with the same name use to have the same specs, regardless of manufacturer.
Licence production is quite common in the semiconductor business, especially with those bread-and-butter products.
If you do not load them with 100% of their max ratings, you will probably not notice any difference.
