2005-10-05 6:09 AM
I can't emulate analog inputs on ST7MDT10-DVP3
2005-09-29 9:45 PM
I want to emulate ST7LITE15 device on ST7MDT10-DVP3 emulator but I am not able to get properly values from analog inputs. I have I/O pins and AD control register configurated as required (floating inputs, no interupts etc). I have connected trimmer potentiometers on these pins in the simplest way and I can read proper digital values (at min and max positions) but when I start A/D conversion I get only FF's as the results. I am doing something wrong or is there any hint that I don't take into account?
Many thanks in advance.2005-10-05 6:09 AM
Can you please send us your init and ADC code in order to reproduce the problem by ourself.
Can you also provide me the start.log file which is in C:\Program Files\STMicroelectronics\st7toolset\stvd7 to be sure that your emulator is up to date. Withe best regardsWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
