2020-08-07 3:31 AM
2020-08-07 6:14 AM
Probably downloaded some code that reconfigures or breaks the SWIM pins/operation
Review the code you last downloaded to determine what you did, and perhaps routes to recover it
2020-08-07 6:17 AM
I have review the code. I am just using gpio and timer. Also SWIM pin is not used anywhere. It is only used for programming. I tired creating new project but it shows the same error. It has stopped suddenly
2020-08-07 9:52 AM
Try to connect under reset. hold reset line, start programming, then release reset line.
