2004-10-25 8:19 PM
How to programm the internal flash on ST10F269-Controller?
2004-10-25 2:38 AM
Are there some known problems by programming the internal flash of ST10F269-Controller? My Programm work like in application note AN1496 descripted but it don't work well. Are there some examples/good ideas?
- For me its possibel to erease the flash block like in applikation note (AN1496 without the here included errors) described. - For me its not possibel to programm the ereased flash block. If I read after my erease- and programm routine there are only 0xff on every memory place. That means, erease work, programm don't work. (Before I erased memory, I programmed it by an external porogramm) [ This message was edited by: andreas73 on 12-11-2004 15:47 ][ This message was edited by: andreas73 on 12-11-2004 15:53 ]2004-10-25 8:19 PM
Could you please tell me what is exactly your problem and what do you mean by ''it doesn't work well'' ?
ByeWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
