2019-07-25 6:59 AM
We are planning to use the SCLT3-8BQ7, but do not want to connect any LEDs to LDi outputs of the chip. The datasheet does not mention how to connect these pins in this case.
Can you please tell us if we should leave these pins floating?
NOTE: This question and answer originated from a customer support case which was handled by us. We regularly review support cases and add any helpful ones here for all to benefit from.
2019-07-25 6:59 AM
In case the LEDs are not used the respective pins (LDi) shall be connected to ground.
2019-07-25 6:59 AM
