2017-03-25 11:28 AM
Hi:
I have designed a smps using eDesignSuite with a VIPer38LE chip... the Power In is 11.1 watts, 96-144 Vac, 60hz and will run at 60KHZ. Is there a method for determining the recommended filter components being X2 caps and the Common mode input choke? Also the NTC?
Thanks, Tom
#common-mode-choke #ntc #x2 #emi-filter2017-05-19 3:10 AM
EMI filters from ST are for datalines, not for power lines.
Best Rds
Richard
