2003-11-02 11:24 AM
How many type of setting in I/O ? (by setting of PADR,PADDR,PAOR)
2003-10-30 9:10 PM
Thank you very much ^^2003-11-02 11:24 AM
it depends on the IO pad you are refering too, you have to check first in the datasheet.
But usually : DDR OR meaning 0 0 floating input 0 1 pull-up input 1 0 open drain output 1 1 push pull output But first you have to refer to the I/O ports chapter in the datasheet of the product you use. Hope it can helpWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
