2008-10-29 3:04 PM
help me to avoid burning my board
2008-10-22 5:52 PM
Please help me to avoid burning my board (str751fr2).
I designed for myself an Evaluation Board. I downloaded the MCBSTR750 blink firmware to flash memory of my board. My evaluation Board is not compatible with MCBSTR750 i/o pins (others pins connected with other peripherals). Can you tell me how erase the full memory without run the ARM. I disable the checkbox ''reset and run'' for uVison before download the firmware. I am new in the ARM world, so I appreciate your help. :-[ [ This message was edited by: Tarlons on 23-10-2008 06:23 ]2008-10-23 4:01 PM
This is the bad of STR7. Lot of people do not want to share his knowledge and ST do not have a good suport.
If I go to LPC forums, i get at least 5 answers. ;) I say this not just for me. Many topics with 0 answers. :-[2008-10-29 11:03 AM
Under the flash menu of your IDE you should find the erase command
2008-10-29 3:04 PM
Quote:
On 29-10-2008 at 23:33, Anonymous wrote: Under the flash menu of your IDE you should find the erase command Thanks, i found it before but I wanted to delete without run the core. i solve this problem desoldering my STR7, and then full erase. Do yo have a str75x ARM? thanks for all :D [ This message was edited by: Tarlons on 30-10-2008 03:49 ]We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
