Help identify ''SGS 28710 5101FG''
Graeme Quinn
Associate
Posted on April 12, 2017 at 05:06
The ECM on my 1987 Ford Bronco has a TO-220 component labelled 'SGS 28710 5101FG'.  I cannot find any information on waht this is.  Is there a description or datasheet available?  I need to replace this component with a current equivalent.
2 REPLIES 2
Erwan YVIN
Posted on April 12, 2017 at 11:14
Hello Graeme ,
I have moved your post in Discontinued product
I think that it is a power mosfet
http://www.st.com/content/st_com/en/search.html#q=IRF730-t=x-reference-page=1
http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/simulators/st-mosfet-finder.html
I think that you can replace by an equivalent one.
     Best regards
                    Erwan
Graeme Quinn
Associate
Posted on April 13, 2017 at 02:03
Thank you, Erwan.  I will de-solder the suspect component (and a known good component with the same part code) and test them.  If this on is bad, as I suspect, then I will know which part to use as a replacement.
Thanks again!
