2011-05-05 7:31 AM
Good day!
I'm writing my first project with STM8. Here are a couple of questions: - AVR-GCC has a convenient attribute PROGMEM (http://www.nongnu.org/avr-libc/user-manual/pgmspace.html) to store data (for example big arrays) in flash not in RAM and read data from flash directly. Does any of the Cosmic/Raisonance/IAR has something similar for STM8? - AVR-GCC has different types of sprintf (optimized integer only (small code) and with float numbers support (big code)) does any of the Cosmic/Raisonance/IAR has this? - Is this possible to just program (not debug) MCU from STVD without running STVP? May be with shortcut? - Is there any simple way to check size of program in STVD without looking to .lst compiler output? Thanks in advance!We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
