2006-07-24 10:46 AM
2006-07-24 7:29 AM
I was searching for worst-case times when doing a sector erase and word programming, but I couldn't find it in the flash reference manual or the device data sheets etc. I am working on a bootloader for the STR712FR2 and the time the device is ''vulnerable'' against power loss when re-programming sector 0 is crucial.
Many thanks, Chris2006-07-24 8:05 AM
hello Chris,
You can refer to STR71x Datasheet on the following link http://www.st.com/stonline/books/pdf/docs/10350.pdf Then Section 2.3.3 : Memory characteristics With regards, Rave2006-07-24 10:46 AM
Thanks a lot! :D
