2010-05-17 9:09 AM
Error configuring STVD to use cosmic compiler
2011-05-17 6:08 AM
Hi vest.kyle,
I had similar problem. I do not know how accurate a solution, but it worked for me...
You must make the choice to toolchain while create a new workspace. Problem does not occur choice when starting project. I hope it will be help. I dont know what is root cause. if you can know, Can you share me?
