2007-06-25 11:52 PM
2007-06-25 9:45 PM
To erase flash memory I use a function called ''HDFlashEraseSector()''. One of the parameters of the function is the frequency. Is there someone who can tell me what is the max value for the frequency, an maybe can explain me why. thanks2007-06-25 11:52 PM
Please look in the ST7 Flash programming doc, this parameter is explained.
http://www.st.com/stonline/books/pdf/docs/8184.pdf Simply it is between 1-8. Start at 1 (fastest) and increase if the programming fails. Regards sjoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
