2007-10-15 3:51 AM
2007-10-15 3:51 AM
Iam using ST7Emu3 emulator for the project. When I try to start the Emulator Debugger ,status on status bar is toggling between RESET and RUN.
Also the RESET and RUN LED's are ON. I tried to modify the memory map as per my requirement and doing so triggers the error GDI error saying it cannot be modified to y config. I have used the same emulator for the same project before successfully.But I have lost the Settings. Can anyone help me how to get around this.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
