2025-06-28 1:49 AM - last edited on 2025-06-28 2:02 AM by Andrew Neil
Hi Usualy I see terms called pushpull configuration,open drain, pull up ,pull down and so on.what are the difference between them
2025-06-28 2:01 AM - edited 2025-06-28 2:49 AM
These are general electronics terms - nothing specific to STM32 or even ST:
PS:
It is conventional to refer to the supply voltage as "up" and ground as "down"; hence:
Again, nothing specific to STM32.
PPS:
Source/Sourcing and Sink/Sinking are also common terms relevant here:
https://electronicsclub.info/ics.htm#:~:text=Sinking%20and%20sourcing%20current
#SourceSink #SourcingSinking #PushPull #OpenDrain #OpenCollector #PullUp #PullDown
PS:
PPS:
2025-07-08 3:35 AM
@Alex_reynold - did that answer your question?
If so, please mark the solution; if not, what needs clarification?
