2020-10-24 2:04 AM
The data sheet contains the following TestCircuit:I wanted to use it to check the switch in PSPICE. Unfortunately I don't get the same results as in the datasheet.
If my assumption is correct: Could you give me a TestCircuit for a PSPICE circuit where I can check the data in the datasheet?
