2006-08-07 11:02 PM
2011-05-17 12:31 AM
Hi Stefano,
You are correct, _TMRx is used instead of _TIMx, this will be corrected in next release of CAPS. Thanks, STARM2011-05-17 12:31 AM
I'm playing with CAPS. I found a discrepance in the constant definition used in the STR91x library and the include file produced by this application. The timer section is defined as _TIMx in the library but the CAPS produce an include file with _TMRx :-Y !!!!! StefanoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
