2007-11-19 9:38 PM
2011-05-17 12:47 AM
I have a comstick that has an embedded USB that I debug through. I debug through OpenOCD and Hitex. I have a target running that I can halt in either debugger. I have tried the commands halt, reset etc and they have no effect, it keeps on running. Does anybody know how to stop my device? Many Thanks, Tom2011-05-17 12:47 AM
I had similar problem, but different board and same environment. I was not able to halt the target and when I issue for first halt command and then poll commnad by the openOCD interface I see: target running I went through some hardware debug and I saw that my reset generator was broken, it stuck to gnd the reset and I was not able either to run or to debug. I think this happends because when you use a debug cable (wiggler, FLASHLink and so on) there is a net conflict between the reset generator and the Jtag interface that is trying in debug to reset the micro by the reset line. Take a look at your hw and check if once the debug cable is plugged in the reset line is moved correctly. In my case I removed the reset generator and changed it with an RC net. Good luck. MarcoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
