2013-04-26 12:15 AM
Hello
Is it possible to boot Linux Kernel via the USB boot mechanism in the SPAEr320 CPU? If yes, what tools are available to generate an image for a bootable USB stick? I hope to get at least a link to an approbriate application note. Thanks Heinz #usb-boot2014-04-05 12:59 PM
hi I am really having problems with uboot. I am using hyperterminal and a usb to serial converter. I press space bar just after a hard reset but nothing happens
2014-09-22 6:10 AM
I dont know, if you already solved you problem but you should test it with a pc with dedicated RS232 interface or with a RS-232 PCI-Card. Almost all USB->Serial interfaces are not working for this purpose. You will have a lot of problems.
