Resolved! ILI9488 TFT display example code.
Can anyone please share ILI9488 SPI tft display 320X480 resolution interfacing with stm8s sample code.
Hi,I'm a beginner in embedded systems.I'm trying out one thing that is I want to generate two different frequencies (100hz & 10hz) with both at 50% duty on TIMER 4 CH1 PWM Generation and TIMER 4 CH2 PWM Generation . Whether it is possible to generate...
A high-frequency DC testing power supply product that uses LM235 to measure the temperature of the heat sink (aluminum), and the measurement circuit is shown in the above figure:The temperature range of the radiator is also within the temperature ran...
Does anybody know if there is any piece of equipment that’s currently available that can be used for copying/programming this chip?
Posted on April 14, 2016 at 08:28Hello, where can I find the spice model of L6598D? I really appreciate it and thanks in advance! Regards Ras #l6598-spice-model-.subckt-.mod
Hi Team,Could you please advice the Body Marking of M24512-DRDW8TP/K? Thank you advance.
Hi friends, I have need to know about pin details of one sensor. I am using MQ-7 sensor interface with Stm32 for my project purpose and I design one custom made PCB design. So ,I buy MQ-7 sensor separately that sensor doesn't indicate any start poin...
Need Prop65 Certificate for STM32F413RGT6511-USBLC6-2SC6
I have recently started learning STM32. Now I`m trying to send data from one Nukleo board to another via NRF24L01. I have already tried to use couple of libraries i found on the internet. But it didn`t work properly. I have read the documentation for...
Please could I have help identifying the component in the attached image to find a suitable replacement as it is shorted. Many thanks, Jazz.
