Others: hardware and software
STHV748 high supply current
Posted on February 20, 2015 at 11:18Hello Community, I want to use the STHV748 for pulsing film-Arrays. The circuit is build like the reference circuit in the Application Note AN3961 figure 33.  The input line are low  so that the output from the ST...
Incorrect ADC readings
Posted on March 03, 2015 at 11:58Hi,I have encountered with some issues with ADC readings.I’m using STM8S003F3 and reading 4 of 5 ADC channels (2, 3, 4, 6) and the readings are not as expected.For testing the ADC readings, I use STM8S003-Discovery a...
lior2 by Associate
  • 884 Views
Debug Dwarf errors, cannot debug using STVD
Posted on March 02, 2015 at 20:24Hello,My problem is using the STVD debugger.  The development platform is win7 64.  The tools are STVD 4.3.6, Raisonance Ride7 7.50.14.0185, RKit-STM8 2.54.14.0283.  The debugger starts normally, no errors, it appear...
rmottes by Associate II
  • 873 Views
Stm8s003f3
Posted on February 17, 2015 at 14:04Hello im working with stm8s003f3 in that unable to use external interrupt pin..in datasheet its mention for 20 pin ic port b will have external interrupt capability.. I have made port B pin as input with interrupt...
ekta by Associate II
  • 973 Views
STM8S105 _ EXTI interrupts
Posted on September 03, 2012 at 15:00Hi all. I'm developping an application on stm8S105S4, requiring among other peripherals, the use of 7 EXTI interrupts. -2 on port D -3 on port B -2 on port E. Scanning the forum, i ve read there is no ITpending f...
thibaut2 by Associate II
  • 1161 Views
Unable to compile STM32F4 demonstration
Posted on March 13, 2013 at 21:54I'm trying to compile the Demonstration sample from ST.com for my STM32F4, using Eclipse CDT and the GNU ARM Eclipse plugin. For more details and the Eclipse project, see Simply clone the project, and import the Ecli...
josef by Associate II
  • 1722 Views
Code size limitation bug in Cosmic compiler 4.3.13
Posted on February 04, 2015 at 10:36Hi folks We're using the 32k code-limited version of the Cosmic compiler: I've just downloaded the latest version 4.3.13 to ensure the bug exists in this, which it does... I suddenly had a report that my code had ...
jro by Associate III
  • 1165 Views
Copy & Paste for component values
Posted on January 30, 2015 at 19:05Is it possible to make fields with component values e.g. capacitors, copyable (e.g. via mouse right click) in eDesignSuite so they can be pasted into other documents or distributors search engines.  This would elim...
robin2 by Associate
  • 1250 Views
Stm8s discovery linux tool for stm8
Posted on January 06, 2015 at 15:55Hi guys, I am developing a tool for linux. grab it from : https://meocloud.pt/link/d1a42ac2-a022-4661-aee2-a1a2188c4c6a/LyPus/ Its for amd64 machines, it will create a folder on /tmp (where it will hold the session...
lmx1 by Associate II
  • 1281 Views
