Others: hardware and software
L9729 or L9749 chips?
Posted on January 19, 2017 at 17:46Hello, I am wondering if anyone knows which chips replaced L9729 0r L9749, it seems they have been obsolete for sometime now?
Rod Cain by Associate
  • 1027 Views
STM8L SD Card
Posted on January 18, 2017 at 17:31i need your help about drive micro SD card with STM8L101F3P6i use the library of Eval-Board of STM8l151 for thisand i have no error in compile Code but the stm failed in initalize routine of SD and can not init thi...
STM8S-Discovery I2C problems
Posted on January 12, 2017 at 15:39I have the problem with I2C comunication.I programmed two STM8S-Discovery with example firmware available in C:\Users\u.iaquinta\Downloads\en.stsw-stm8069\STM8S_StdPeriph_Lib\Project\STM8S_StdPeriph_Examples\I2C\I2...
u23 by Senior
  • 1318 Views
edesignsuite---promovideo---feb-2017
Posted on January 11, 2017 at 20:24eDesignSuitehttps://my.st.com/analogsimulator is an easy-to-use comprehensive software tool suite ready to help customers in their needs by transforming application requirements into satisfactory solutions accurate...
0690X00000605zYQAQ.png 0690X0000060QQDQA2.jpg 0690X0000060QQKQA2.jpg 0690X0000060QQNQA2.jpg
STM8S - 32bit atomic access
Posted on January 02, 2017 at 09:12Hi,I'm stm8 newbie, and i wonder if i can do assumption, that reading uint32 variable will be atomic.There is simple function returning system time measured in ms using uint32_t variable, and it's looks like follow...
STiH273 RTP streaming support
Posted on January 13, 2017 at 19:31Hello, Im getting IP Video stream from http://questtel.com/item.php?id=1&product=21, my application requires PTR protocol, I need to know if STiH273 support RTP protocol or not, if not - could you guys recommend me...
KA3100D - Fairchild IC 1:1 Alternative
Posted on January 06, 2017 at 13:22We are using Fairchild Semiconductor KA3100D IC SOP-16 SMD Package in our medical products with annual consumption of 1000. Currently this IC is EOL now (Year 2008)But since it is used in regular production, we nee...
STVD Problems under Windows 7!!!
Posted on June 17, 2011 at 15:53Hi, I am a project engineer. I use ST7,STM8 as microcontroller in my projects. And i use COSMIC as a complier. And i use STVD and STVP. I had not any problem while ? was using these programs under Win XP. But ? have a...
hsynenko by Associate II
  • 3591 Views
