Others: hardware and software
What is #error cgstm8 .... PANIC! MOVCNT
What is the meaning and root cause of following error:#error cgstm8 xsnprintf.c:195 >123<@generate() PANIC! MOVCNTI am trying to build a custom printf routine. This shows up only after I change the type of some parameters.
MRodr.12 by Associate
  • 974 Views
SPWF04SA - UART_IRQHandler issue
Hello,I am developing a program with a WiFi socket user interface. I can communicate with the module using the Socket Test App. I give a certain command and my MCU does something. I generally found this to work fine until it came back after running ...
Hello, i'm searching for the Source Code for the Eval Board STEVAL-ILD004V2? There is only the compiled Firmware Version. Can anybody help me?
Posted on November 17, 2017 at 14:08Hello,i'm searching for the Source Code of the EVAL Board STEVAL-ILD004V2 with STM8S103F2 Controller?I can only found the compiled Firmware.Can anybody help me?Best Regards,Stefan#steval-ild004v2-source-code?
Propper use of RSF bit.
According to the datasheet the RTC_ISR1_RSF bit is by hardware when the shadow regs are updated. Is it safe to assume that the shadow regs will not be updated when the RSF bit is already set?
mschn.17 by Associate II
  • 884 Views
