Resolved! Orcad and Viper06hs Model
Could i have access to the Orcad model for the Viper06HS, Th
Our company is currently reviewing medical device solutions for cerebral blood flow velocity measurement and embolism detection. We are at the proof-of-concept (POC) stage and have not yet planned a mass production roadmap.We have selected a TCD prob...
I'm using cr95hf-vmd5t RFID reader, I will use NTAG 424 DNA tags with NDEF message.Does the cr95hf-vmd5t support NTAG 424 DNA?If yes, can I use authentication?
In the datasheet for the STSPIN230, the pin description for SENSEU says "Sense output bridge U (must be connected to SENSEVW)."Is this a hard requirement? I would like to be able to sense both currents separately with separate resistors in order to K...
I was following the Application note document on [AN2659](https://www.st.com/resource/en/application_note/an2659-stm8-inapplication-programming-iap-using-a-customized-userbootloader-stmicroelectronics.pdf) as my purpose was to implement a custom boot...
"Hello, could you please tell me what component corresponds to the SMD code 'DUJ' on this diode? It appears to be manufactured by STMicroelectronics and is mounted near the 12V power input on a hard drive circuit board."
So I want to order a STM32F407VG. But I would love to know where they are being shipped from. Because I don't see any VAT being added to my order. I could not find the information anywhere.I live in europe so I just wanted to know where they ship the...
Hello,Years ago, I integrated the DFUSe DLLs (STDFU.dll, STDFUFiles.dll, STDFUPRT.dll, STTubeDevice30.dll) into my 32-bit .NET application to update firmware on my devices. Everything has been working perfectly and is still running smoothly.Now, I n...
Hello,I’m working on interfacing the Bosch BME688 sensor with my STM32 Nucleo-F446ZE development board using the BSEC library. The sensor is correctly providing temperature, pressure, humidity, and gas resistance data. However, I’m facing an issue wh...
Hello everyone,Does anyone happen to know the exact equivalent for the part number "G23"? I've been researching it, but I'm not entirely sure whether this code matches the Schottky rectifier STPS2L25. Maybe someone has used it before or is familiar w...
