Others: hardware and software
Use specific NMEA data set
Hello I have another question     I am currently working on a microcontroller project I am building a GPS tachometer which transfers the NMEA data of the GNSS 4 Click Module from Mikroe via UART to my STM32L052K6T6 and outputs it to a display   How c...
MSchmutz by Associate II
  • 2247 Views
About STM8S Flash block write
The chip I use is STM8S003F3. When using Flash block erase, it is executed in RAM. If the offset of the Flash address is used with a 32-bit variable, the execution will cause an error. Can this 8-bit microcontroller use 32-bit addressing in RAM?
LXiao.11 by Associate
  • 867 Views
Hello, I would like to read and write an ST90402C6 mcu and i own a jegger flasher 5 but i cant choose this mcu model. I can select only ST92F120 ST92F124 ST92F150 ST92F250. If anyone knows of any other way to be able to read this chip? Thank you
Hello, I would like to read and write an ST90402C6 mcuand i own a jegger flasher 5 but i cant choose this mcu model. I can select only ST92F120ST92F124 ST92F150ST92F250.If anyone knows of any other way to be able to read this chip?Thank you
Jcloa.1 by Associate
  • 1205 Views
Details on STM8 chip ID and memory size?
Hi,I am the author of an OS tool flash tool named "stm8gal" for programming the STM8 via the ROM bootloader. Currently I check family type and memory size by probing different addresses. This is extremely ugly and may fail in devices I couldn't test ...
GIcki by Associate II
  • 837 Views
