Others: hardware and software
Usage of Window watchdog generates a reset when MCU enters Halt mode and Independent watchdog continues running in Halt/Active-halt mode
Hi ST Team,Hope you guys are doing well !!!.Can you explain me in detail regarding the usage of Window watchdog generates a reset when MCU enters Halt mode  and Independent watchdog continues running in Halt/Active-halt mode. If you have any document...
Resolved! Can't connect to STM8L052C6
Hi,I'm attempting to connect to STM8L052C6 with ST-link and receiving an error, "Cannot communicate with the device !"I've read every forum post on google related to the issue and tried just about everything to connect.Finally I found in the manual f...
CDarw.1 by Associate II
  • 2982 Views
cosmic compiler error?
hiComsic STM8 compiler suite version: 4.4.12.I am using this compiler version together with ST's STVD.In the sample code attached, with line 13 conditional define set to 0, the compiler yields compilation error (my intended implementation), and the a...
Keeloq firmware
In DT0094, KeeLoq RX application over S2-LP, the following is mentioned:KeeLoq firmware example for RX node available on request through local marketing / sales representative.Has anybody got a copy of this?
VTrea.1 by Associate
  • 792 Views
