Others: hardware and software
Not able to generate 6 step pwm signal using timer1
Hi,I am working with stm8s105c6 controller. I want to generate 6 PWM using timer1. For that I am using 6 step PWM sample. I am getting pwm at pc1, pc2, pc3 but complementry pwm at pb0, pb1, and pb2 is not available.At pb0, pb1 and pb2 I am constantly...
Ajadh.1 by Associate II
  • 4771 Views
  • 15 replies
STM8S SWIM pin unused handling
Hello everyone.I am in trouble with the SWIM pin of STM8S.According to the data sheet, unused pins should be set to OUTPUT.However, I would like to keep SWIM pins in a state where they are normally unused and can be debugged only when necessary.How c...
ota-s by Associate II
  • 2879 Views
Resolved! Which STM32 flasher to use for STM8
Hi all, I'm working on a part that has implemented something very similar to the ST-provided user bootloader for the STM8. I've tired uploading a binary using several versions of the STM flasher but none of them seem to work. Is there a script availa...
Konami by Senior II
  • 983 Views
how to change c language from c90 to c99 in stvd
Hi,I am using STVD to debug program for stm8s105c6 MCU. Here am able to compile code properly, and using cosmic compiler.I am getting error for Inline, and also prototype missing, semicolon missing, invalid constant expression, etc. errors are comin...
  • 1740 Views
Resolved! EEPROM internal write cycle (M24M01 )
Hi there, I am new to the embedded system and now am using M24M01. When I am trying page write with I2C protocol on the EEPROM, I found a weird problem with my oscilloscope. I sent out the command, the waveform is like fig.1, it forms of slave addres...
PCHEN.2 by Associate
  • 2848 Views
