Others: hardware and software
ADC temperature dependence. Broken or defective?
Our company has developed a thermostat based on a microcontroller STM8L151K4T6. Many thermostats from the manufacturer were rejected. The analysis showed that the microcontroller does not correctly measure the voltage at the external terminals. The m...
OMaks.1 by Associate
  • 1695 Views
How does the function work? void Delay(void action(void), int NumberofTIMCycles); and how the NumberodTIMCycles always hold the value 10. while there is no declare any
/** ****************************************************************************** * @file main.c * @brief Adjustable LED blinking speed using STM8S-DISCOVERY touch sensing key * Application example. * @author STMicroelectronics - MCD Application Tea...
Mkuma.12 by Associate II
  • 1213 Views
vnd7e025 - input capacitance limits
Very interested in your vnd7e025. Datasheet doesn't have load capacitance limits - but states its rated for "capacitive and inductive loads". Can you please provide details about maximum capacitance and/or inrush magnitude and duration allowable fo...
JBrin.1 by Associate
  • 1257 Views
ADC Accuracy
Hi Guys, i am using STM8S003F3 controller and i want to that how can i achive 0.1v accuracy when my ADC resolution is 1023 and my total count is 2000.
MAnsa.1 by Associate II
  • 8471 Views
  • 13 replies
We are using the STM8L052R8T6 CPU, The normal current is about 15 microampere, but in several units, the current jump to about 34 milliampere.
We are using the STM8L052R8T6 CPU. The CPU is in Wait mode most of the time, so the current is about 15 microampere . In several cases, the current jump to about 34 milliampere (yes.. 34 mA!)We are using the STM8L052R8T6 CPU,  The CPU is in Wait mode...
EGaba.1 by Associate II
  • 1973 Views
6 step PWM program is not working
Hi,I am using stm8s discovery board with stm8s105c6 microcontroller. I am using 6 step PWM generation sample code bu using stm8s_periperal_library.I am able to generate PWM at PC2, PC4 only but I am not getting PWM at other pins and not even compl...
Ajadh.1 by Associate II
  • 877 Views
ST Visual Developer says ''out of memory'' and crashes when trying to launch the programming tool
Posted on December 06, 2017 at 19:37I have been using ST Visual Developer for 6 months without this issue. I was having problems with a project I am working on and thought that re-installing the tool might help. Once I un-installed the tool and inst...
