I want latest Rohs and Reach Certificate.For following Part Number
BAS70-04FILML6566BL6566BHM24256-BRM24512-DFM24512-RSMAJ15CASTH3N150-2STPS2H100USTTH8R04G-TRUSBLC6-4
Autec bought the above MPN, but I can't find the marking code in the datasheet or in other technical documents.Where can I find thin information?Thanks!
I need some help with getting started with the ST motor control system. I have the STEVAL-SPIN3204 evaluation board. I have gone through the instruction manual and getting-started guides but these are not helping.I installed the ST X-CUBE-MCSDK as in...
I need pictures authentic ST Electronics IC chip markings to use as comparison to identify counterfeit parts. This must include ALL markings and identifiers on all sides. Specifically the Real Time Clock IC M48T86PC1. email this info to rmartin@npas....
Below is a screenshot from Teseo-Suite for my Teseo-LIV3FL GNSS ModuleLighter flag color means the satellite is not used. As you can see GPS satellite with PRN 16 has higher SNR (23dB) than PRN 9 (21dB) which means the signal quality should be better...
Hello Team,Please let me know the inductance value of the passive filter IC EMIF02-SPK03F2. In the datasheet, the capacitance value is listed but the Inductance value not showing.
Please declare the CMRT for the MPN M24C02-FMC6TG, Since the CMRT document provide by ST Microelectronics has been declared on Company basis.Sanmina expects the customer to declare the CMRT template on "Product wise". Please do the needful.Kindly don...
