Are TSV321RAILT & TSV321RILT pin configurations exactly the same?
n_minakata
Associate
Are the pin configurations for TSV321RAILT and TSV321RILT exactly the same?
I'm having trouble finding this information in the datasheet.
1 ACCEPTED SOLUTION
Accepted Solutions
Peter BENSCH
Welcome @n_minakata, to the community!
The two order designations differ exclusively in the offset voltage, which is indicated by the inserted letter 'A'. The offset values are given in the data sheet, table 3 for VCC=3V and table 4 for VCC=5V.
The pin assignment is exactly identical for both.
Does it answer your question?
/Peter
2 REPLIES 2
Peter BENSCH
/Peter
n_minakata
Associate
I understand perfectly.
Thank you for your prompt reply.
