2016-03-08 6:40 AM
Do you have any plans to release a version of this sensor with a smaller FieldOfView?
As your presentation note you use a kind of diode matrix as photon input, do you plan to output the data of each diode to identify where the obstacle is?Per example at 2 meters with a 25degree FOV the obstacle could be anywhere inside a 0.44 meters radius circle. Is is good for obstacle detection but not for obstacle avoidance because a robot with 0.5 meters diameter can't move on a 0.7 meters passage because it will detect walls. #vl53l02016-03-18 5:35 PM
